ok so i finally installed my 30mm okosi have a 50 pilot and 160main in them at the moment . so when i kicked it over it kicked first kick and without the choke and it is the middle of winter here in australia. so im guessing im rich on the pilot put then im questioning that theory becasue when i pulled the chokes on the revs picked up shouldnt it bogg down when the chokes are pulled on whilst running,
Im running 48's and 168's on mine right now. I went down from 50's and 172's.
Id say you're rich on the pilot and maybe a little lean on the main. Id try a 48 pilot and 168 main like Im running. See how it goes form there. Have you done a plug chop yet?
When the engine is still cold it can handle the extra fuel. Basically you just did have enough fuel from the pilot to start the engine. When you choked it, it got more fuel which to a degree is better on a cold engine. Let it warm up to operating temp and pull the choke out. I bet it shuts off.
