eagle Posted June 20, 2007 Report Posted June 20, 2007 Wondering if the 795 piston has a relocated wrist pin of 2mm, 5mm, or 7mm? IA can I just install these with my 4+5mm crank or do I still need a head mod for the extra stroke? Do these pistons just adjust for the long rod? Thanks Quote
Master of Faster Posted June 20, 2007 Report Posted June 20, 2007 795 series have wrist pins relocated 5mm. They adjust for the longer rods but you still have to compensate for the extra stroke by cutting the heads or running a spacer plate. Quote
