01blckbansh Posted June 18, 2007 Report Posted June 18, 2007 i'm replacing my clutch and impeller at the same time . i have the clutch cover gasket. do i need a water pump gasket also??? i know it prob. been coverd a few times. did a search on water pupm gasket and didn't really find an answer. thanks for any help. Quote
Fireroad Express Posted June 18, 2007 Report Posted June 18, 2007 i'm replacing my clutch and impeller at the same time . i have the clutch cover gasket. do i need a water pump gasket also??? i know it prob. been coverd a few times. did a search on water pupm gasket and didn't really find an answer. thanks for any help. [/quotet. if it was me, i'd replace the gasket. some people wouldn't and get away with it. why leave it to chance though? just something else to go wrong. Quote
fastbanshee8 Posted June 18, 2007 Report Posted June 18, 2007 Since you're replacing the impellar, you might as well go ahead, and replace the impellar bearing, and seal, while you have it down that far. If you don't, and they fail, you will end up replacing both gaskets, the seal, the bearing, and probably the impellar, and maybe a few other things. Quote
01blckbansh Posted June 18, 2007 Author Report Posted June 18, 2007 i have engine seal kit. would that have the seal in it? you guys are right. i will go ahead and replace the bearing , gasket and seal. thanks for the help. Quote
fastbanshee8 Posted June 18, 2007 Report Posted June 18, 2007 My engine seal kit didn't have the impellar seal in it, so I had to order the bearing, and seal seperate. Quote
01blckbansh Posted June 18, 2007 Author Report Posted June 18, 2007 i just looked at my kit. no seal either. i'm going to order the bearing and seal tomarrow. thanks again for the help. Quote
Washburn Posted June 19, 2007 Report Posted June 19, 2007 Im going to replace the gasket but I cant see replacing the bearing unless its already bad. Quote
KaosBanshee44 Posted June 19, 2007 Report Posted June 19, 2007 I've seen a few topics about the water pump seal and barring. I just replaced all mine just to be safe. But you have to remember when you put your coolant back in that you don't make any air pockets in the line or it won't cool right. I'm having that problem right now. I would definitly listen to someone that has learned from a mistake that just saying it...lol There is a bolt behind the exhaust that you have to unscrew and it gets all the air pockets out the line. Here is a pic. Quote
Devans Posted June 19, 2007 Report Posted June 19, 2007 I've seen a few topics about the water pump seal and barring. I just replaced all mine just to be safe. But you have to remember when you put your coolant back in that you don't make any air pockets in the line or it won't cool right. I'm having that problem right now. I would definitly listen to someone that has learned from a mistake that just saying it...lol There is a bolt behind the exhaust that you have to unscrew and it gets all the air pockets out the line. Here is a pic. I thought those were to drain the coolant from the jugs Quote
fastbanshee8 Posted June 19, 2007 Report Posted June 19, 2007 The bolt in the cylinder walls, is to drain the coolant. To get the air out of the system, I just fill it up, and let it idle for a little while, with the radiator cap off, and that seems to do the trick. Don't fill the radiator all the way up with coolant, or some of it will come out, when the air pockets come to the surface. Quote
01blckbansh Posted June 20, 2007 Author Report Posted June 20, 2007 thanks for the help. i'm going to put engine ice in . thanks again. Quote
