dekker Posted June 13, 2007 Report Share Posted June 13, 2007 Hey Guys, I have been doin a little drag racing up at silver .... on the dunes not at the track but I was wondering what you thinkg would be the best sprocket combo. My mods are in my sig. Im running 8 paddle haulers and a 15 tooth front as or now and I launch in first. Last week I dusted another banshee and beat my cousins yz250 10 out of 10 times on the wet sand but he has no paddle... anyway back to gearing . Should i take the front sprocket down or leave it where its at and launch in 1st Thanks Zach :biggrin: Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 13, 2007 Report Share Posted June 13, 2007 I'm a fan of launching in 2nd, 3rd always seems to pull ridiculously hard so the quicker I can get to that gear the better IMO, and 1st always seems so short. Try a 14t up front and see if you can launch in 2nd. If not sounds like ur doin good how it is. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 14, 2007 Report Share Posted June 14, 2007 14/42, launch in second. Play with the air pressure...probably between 3 to 5 PSI, depending on the sand... Quote Link to comment Share on other sites More sharing options...
dekker Posted June 14, 2007 Author Report Share Posted June 14, 2007 Thanks for the info guys I appreciate it. So when u guys start in second do u just pin it and drop the clutch ??? -Zach Quote Link to comment Share on other sites More sharing options...
dekker Posted June 14, 2007 Author Report Share Posted June 14, 2007 Goin up tomorrow.... ill throw on the 14t and see how shee does.. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 14, 2007 Report Share Posted June 14, 2007 Pin it and feed the clutch out....if you just dump it..normally you'll either wheelie too much or just spin. Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 14, 2007 Report Share Posted June 14, 2007 You can either feather the clutch or practice alot and work your body weight around. That's usually what I do. Quote Link to comment Share on other sites More sharing options...
wesw Posted June 15, 2007 Report Share Posted June 15, 2007 16 up front in 1st gear. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 15, 2007 Report Share Posted June 15, 2007 I used 15/42 gearing 2nd gear launch with my old dune set-up. Quote Link to comment Share on other sites More sharing options...
xLastShotx Posted June 15, 2007 Report Share Posted June 15, 2007 15-41 second gear launch with 20x10x10 8 paddles Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 15, 2007 Report Share Posted June 15, 2007 15-41 second gear launch with 20x10x10 8 paddles You want 8 inch rear rims for drag racing. 10 are good for duning more than drag.... Quote Link to comment Share on other sites More sharing options...
dekker Posted June 15, 2007 Author Report Share Posted June 15, 2007 Thanks for the replies guys. Dajogejr I do have 8 inch rims which is a plus. Headed up this morning. Hopefully there will be some ppl there Fridays are usually decent. Still have not had a chance to line up with a 450 yet ! Quote Link to comment Share on other sites More sharing options...
dekker Posted June 19, 2007 Author Report Share Posted June 19, 2007 Alright guys .... good trip to silver ... so i get in my first drag race..... yzf450 and heres how it goes.... he beats me out of the hole of course.... then i hit second and am pulling ..... hit third and im even then pull ahead by about a bike.... then im like alright time for light speed and go to shift into fourth and the fucker will not shift up im pretty sure i almost broke the shifter off and it would not go. It did this multiple times between second and thrid and third and fourth and needless to say u cant drag with 3 gears.... so yea im gonna check my shifter adjustment. Needless to say he shifted and passed and i was pissed the only way i could get that thing to go was to reach down and pull it with my hand. but it seemed to shift alright in the lower RPM"s so i duno whats up Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 19, 2007 Report Share Posted June 19, 2007 Time for an override :biggrin: Lol But hopefully not. Quote Link to comment Share on other sites More sharing options...
strokerace Posted June 19, 2007 Report Share Posted June 19, 2007 override for sure or back off the throttle Quote Link to comment Share on other sites More sharing options...
