ban-shred Posted June 10, 2007 Report Share Posted June 10, 2007 (edited) i was 6th gear full throttle and then TOOCKKK i heard this sound,i stopped my banshee and there were strange sound coming from my engine(clutch or transmission).so i opened the clutch and found 2 clutch spring that had losen,i tighten them,i try it back without looking more at the clutch, after i started it again the same sound was coming from the clutch or transmission.Also when i did my oil drain i founded a small block of metal on my magnetic plug :ninja: he's still moving and all gears shift correctly.I was taking a lot of false neutral before this happen and he was doing SOME scratching sound coming from the clutch...any idea on what i should start or what could it be?? Edited June 10, 2007 by ban-shred Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted June 10, 2007 Report Share Posted June 10, 2007 maybe bent forks and now chipped gears. Quote Link to comment Share on other sites More sharing options...
