bronco91shee Posted June 6, 2007 Report Posted June 6, 2007 first is my shee. it has fmf fatties, k/n not in box. boysen reeds. i just got my cylinders ported and head milled .030" what do you think would be a good starting spot for jetting. im very close to sea level, and currently dont remeber exactly what is in it now, but it ran strong. second question, girlfriends z400 has a ct pipe and header, k/n, and no airbox lid. it lately is smoking alot, wont idle on its own once warmed up, and loses power in the very top of power band. do you guys have sugestions as to what these jets should be at? it was a repo quad that had all of this work done to it. it may be wrong, but i cant find online where a good starting place would be. thanks in advance Quote
Bansh-eman Posted June 7, 2007 Report Posted June 7, 2007 im going to assume you have stock carbs because you didnt say other wise. back when i was running stock setup with similar mods i had 320 main 27.5 pilot stock needle 4th clip. i was a bit rich so you should be ok some where around a 300-310 starting same pilot and needle Quote
