well as you all know that ive rebuilt my banshee twice and the problem keeps making things worse.ive put a vitos 4 mill crank in and that went bad so i had it rebuilt with hot rod bearings with stock rods 80 over pistons the heads been milled 10 thousands 34 mm keihins there was a grinding noise behind the side cover not sure think its the kick start idler gear now the fly wheel and the waterpump gear both sides came loose and the water pump side has a hole in it as what i put in my last post this thing is killing my pocket HEL PLEASE
