just got back from a trip to the badlands in attica ind while i was there i noticed coolant coming from the overflow hose whenever i would stop checked the temp on the cylender heads they were at 203 each is this normal any help would be great thanks
how did you check the temperature of the head?
I have a water temp gauge that monitors the water temp coming right out of the cylinder head. It runs inbetween 160 and 180. The head is a lot cooler than that. You really cant tell how hot your machine is running by using an temp gun on the out side of the engine. The head holds heat in there for I would imagine that the engines temperature was way more than 203 deg.
i used a raytec temp gun i havent got a water gauge yet i also checked the top of the rad it was 180 so was the upper hose the lower was 155
