2strokeme Posted May 28, 2007 Report Posted May 28, 2007 as some of you know i messed my flywheel up pulling it off. Wondering if i should go on a get a lightened flywheel. Seller says i'll have much better response and icreased speed through gears. Is this true? Quote
HotCarl Posted May 28, 2007 Report Posted May 28, 2007 Depending on the type of riding you do it can help or hurt you. Also you lighten a stock flywheel by machining material off of it, so if your flywheel is in good shape you can take it to a machine shop. Quote
ClimbAnyHill Posted May 28, 2007 Report Posted May 28, 2007 Depending on the type of riding you do it can help or hurt you. Also you lighten a stock flywheel by machining material off of it, so if your flywheel is in good shape you can take it to a machine shop. I understand how it helps. How would it hurt my bike in any way? I dune & trail.. Thanks. Quote
blowit Posted May 28, 2007 Report Posted May 28, 2007 I understand how it helps. How would it hurt my bike in any way? I dune & trail.. Thanks. For most applications, the lightened flywheel is a good thing on the Banshee. The reduction of mass reduces crankshaft inertia and can lead to stalling if uses on technical tracks. The extra weight also helps in traction by helping smooth the power delivery to the rear tires. Unless you are 230lbs or over and riding in woods or technical trails, I would say go for it. Brandon Quote
ClimbAnyHill Posted May 29, 2007 Report Posted May 29, 2007 For most applications, the lightened flywheel is a good thing on the Banshee. The reduction of mass reduces crankshaft inertia and can lead to stalling if uses on technical tracks. The extra weight also helps in traction by helping smooth the power delivery to the rear tires. Unless you are 230lbs or over and riding in woods or technical trails, I would say go for it. Brandon I was thinking of going for it. I'm about 175-180 lbs. I don't do woods & my trails are pretty open & hit them hard. I like to climb stuff :biggrin: I ride Pismo, Dumont, Glamis so I should be good with this lightening mod? Thanks. Quote
Snopczynski Posted May 29, 2007 Report Posted May 29, 2007 You loose a little initial holeshot power, but you will gain quicker revs and more torque from a lightened one. Quote
