NEWFOUNDLAND BANSHEE Posted May 26, 2007 Report Posted May 26, 2007 Hi Everyone, I'm new here but not new to quads at all. I wanted to get your guys opinion on my jetting. 01' Banshee DMC ALIEN IPIES, BOYESEN POWER REEDS, K@N FILTER WITH LID ON AND SNORKLE REMOVED, 280 MAINS AND 30 PILOTS 1.5 TURNS OUT(AS PER DMC'S RECOMMENDATION) AND I RIDE AT SEA LEVEL TO 500 FT MAX MOSTLY BETWEEN 60-80 F. Thanks alot Quote
BellicoseBanshee Posted May 26, 2007 Report Posted May 26, 2007 I came across this some time ago while searching the Jetting and Exhaust forum. Scroll down to Q&A number 41, it should help you find a good starting point. The pinned topics at the top of the Jetting and Exhaust forum are good reading also, if you want/need to learn more. http://www.dfn.com/benkaren/jetfaq.html Others with more experience than me will be able to get you squared away if the above is not sufficient. Good Luck! :thumbsup: Quote
