r/atvshee Posted May 23, 2007 Report Share Posted May 23, 2007 I find it very confusing that only the tail light works and not the headlights. I've changes the fuses, checked wiring, ect. Can somebody help me out so i can get the lights working by this weekend? Quote Link to comment Share on other sites More sharing options...
blowit Posted May 23, 2007 Report Share Posted May 23, 2007 I find it very confusing that only the tail light works and not the headlights. I've changes the fuses, checked wiring, ect. Can somebody help me out so i can get the lights working by this weekend? Tell us what you are working on. What is the history with your problem. Brandon Quote Link to comment Share on other sites More sharing options...
bansheeyfz Posted May 23, 2007 Report Share Posted May 23, 2007 raptor 700 Quote Link to comment Share on other sites More sharing options...
joneser4u Posted May 23, 2007 Report Share Posted May 23, 2007 Probably dumb, but did you check the bulbs? Quote Link to comment Share on other sites More sharing options...
blowit Posted May 23, 2007 Report Share Posted May 23, 2007 Probably dumb, but did you check the bulbs? Follow wires from voltage regulator to head lights. Sounds like something is unplugged or a wire is pinched. Fi you are putting bulbs in the head lights and they are blowing, you have a regulator problem. The tail light is sometimes resistant to higher voltage because of higher resistance. Grab your multi meter and get to it. Brandon Quote Link to comment Share on other sites More sharing options...
r/atvshee Posted May 23, 2007 Author Report Share Posted May 23, 2007 Follow wires from voltage regulator to head lights. Sounds like something is unplugged or a wire is pinched. Fi you are putting bulbs in the head lights and they are blowing, you have a regulator problem. The tail light is sometimes resistant to higher voltage because of higher resistance. Grab your multi meter and get to it.Brandon Alright i'll try that. The bulbs are fine. Even if they weren't I've tried it by wiring a set of trail techs with new bulbs and still nothing. So bad bulbs are out of the question. But what blowit is saying does sound like a solution. Thanks. Quote Link to comment Share on other sites More sharing options...
theshee Posted May 23, 2007 Report Share Posted May 23, 2007 What year? 06s had some jacked up wiring on some of them. Quote Link to comment Share on other sites More sharing options...
