i noticed that when my handle bars are straight my left front tire is pointed out . it's nothing drastic but noticable. my steering stem doesn't appear to be bent. is there a way to adjut it through the tie rod ends? any input and advice would be appreciated. thanks.
yea, put you bars straight see wich one needs to go in or out then just take the rod end out of the spindle or steering stem, loosen the lock nut and turn it in our out to bring the tire closer or further. really simple. If it doesnt come right out, leave the castle nut on a little and tap it out with a hammer. That way you dont bust up your threads. Measure you toe from rear of the tires one to the other and then the front of them tire to tire and make sure they are the same distance apart front and back. I think the manual says something about toe in/out in it. I dont think its 0 degree, but it works fine.
thanks for the help. i appreciate it
why are you telling him to take the tie-rod end out of the spindle??? that is totally unnecessary. all you have to do is loosen the jam nuts and turn the tie-rod. one end is regular thread and the other end is reverse thread. so you turn the tie-rod one way and it lengthens it, you turn it the other way and it shortens it.
thanks . i'll give it a try
holy fucking shit! Im soooo sorry. didnt know one was reverse. Ill go slap my mother now. like itll take more than a few minutes either way. :notworthy: :notworthy: :notworthy:
