EatMyDustBanshee Posted May 15, 2007 Report Posted May 15, 2007 I'm just wandering. I've got NGK R's, but Oreilly's has some NGK Iridiums; would this be good for a 2stroke. Quote
sldbanshee Posted May 15, 2007 Report Posted May 15, 2007 I'm just wandering. I've got NGK R's, but Oreilly's has some NGK Iridiums; would this be good for a 2stroke. listen bro go with the nippodenso w24esu plugs there the best for the sheeee man Quote
dawarriorman Posted May 15, 2007 Report Posted May 15, 2007 The only real advantage to the iridium plugs is longer life. They are really hard to foul, and even if you do, you fix the cause of the fouling and they'll clean up enough to keep running. I used to use them because I put the airbox lid on when I washed the shee, and would always forget to take it back off until I rode it, fouled the plugs and it stopped running. Take the lid off, it would fire right up and run fine. They lasted for over a year with me doing that probably a dozen times. Only reason Im not using them now is I still have new sets of b8es lying around I figured I might as well use. I'll probably get them again next time I buy plugs. Quote
swrbansheeboy Posted May 15, 2007 Report Posted May 15, 2007 if you've got money falling out your ass then get some high zoot plugs but i've never ran anything but ngk br8es plugs. there cheep and i've ran them for up to 3 years before with no problems...plus there cheep! Quote
