qboronyrican Posted May 10, 2007 Report Posted May 10, 2007 i was reading the threads about jetting and notice that a diagram of the needle has 5 clips/notches and always read about everyone having 5 but mine has 6....is there something wrong with this????? Quote
Bansh-eman Posted May 10, 2007 Report Posted May 10, 2007 no... not every needle is the same... some have 1 notch some 3 some 5 some 6... it all depends who made it... Quote
qboronyrican Posted May 10, 2007 Author Report Posted May 10, 2007 ohh ok....so when someone tells me i should be on the 3 notch or 4 or 1st....whatever.....how do i know if they are right for my needle???? dont they have to have the same needle to give that advice???? Quote
XxMeltIcexX Posted May 11, 2007 Report Posted May 11, 2007 ohh ok....so when someone tells me i should be on the 3 notch or 4 or 1st....whatever.....how do i know if they are right for my needle???? dont they have to have the same needle to give that advice???? Every engine has its own preference, some know an approximate way you should be heading if they have personal experience with a similar setup, but very unlikely... If they tell you to take the clip up that means it will make it leaner (to some people its the other way around, depends on the way they look at it) - the higher the clip is the leaner it is, and vise-versa.. But there are many kinds of needles, AEG,CEL,CEG, etc.. all of which are larger/smaller than the other. Eric Quote
