JET 99 Posted May 8, 2007 Report Posted May 8, 2007 i have a fresh built motor with a .020 bore,t&wed stock stroke, cyl. and case ported, 20cc dome, 33pwk, v3's, +4 timing ...... i have some mods on suspension too.. dude unless you want to drag or play in the dunes you are talking a motor w at least a +4 swinger which wouldnt be so hot in the woods or tight trails.. if your cylinders are ported and you do the standard mods you will have more than you need on a stock swinger.... Quote
Michael Jackson Posted May 8, 2007 Report Posted May 8, 2007 you should chnage your suspension no matter how big your motor is or what kind of riding you do. in any form, the stock suspension is total garbage, especially the front end as far as how many cc's u can make it.. you could make it 393847349393747494393738309, if you wanted to Quote
