Quint Posted May 3, 2007 Report Posted May 3, 2007 ok so just going through the finishing list. was filling up with coolant, put the 1.25 litres of water in first but it was full at that! then water starts dripping so i check all the hoses and then see it coming out from where the cylinder head seals against the cylinders, it seems to be coming out from all around. water is fairly leaking out, though so it seems major. and i did put the metal gasket on as it said in the clymers too. I torqued up the head like it said in the clymers and in 3 steps. was a new torque wrench too. have checked nuts and all feel tight. I have had the head skimmed, new pistons & rings, gaskets, hoses and billet waterpump impeller. what have i done???? Quote
