I'm new to the whole banshee thing but would like some info on some carbs I hear that they are a good start for power I have a 2002 with a coolhead 18cc domes and t-5 pipes and no air box everything else is stock what if any carbs should I look at buying
before you go throwing carbs on... theres a few thingsyou should do first...
porting will bring the most power out of that motor from any mod... get it ported THEN get carbs to match.... if you go too big for your setup your drownding your motor and losing power...
also look at some VF3 reeds, and adjustable timing plate
an adjustable timing plate allws you to advance or retard your timing +10 to -10 degrees by turning the plate... adjusting will give you more bottom end ( that the banshee lacks ) at the sacrifice of some topend...
id say get your self a nice port job... thats going to make your motor run night and day differant... do you ever plan on going to a stroker crank? if you do you might wait and save to get the crank as well casue your going to have to have it reported once you drop in th crank to change the port timings..
