ban1 Posted May 1, 2007 Report Posted May 1, 2007 i have oiley grease stuff leaking from exhaust flanges the one on the left appears to be leaking more than the right is this normal or is there a real problem. also can anybody tell me what size of jets they would be if they had a 5/64 in hole in them,the parts store was closed when i was trying to jet so i drilled some old jets out but still need bigger ones and dont know what size to get. thanks ken Quote
Bansh-eman Posted May 1, 2007 Report Posted May 1, 2007 the oil coming out the one side is becasue your carbs arnt synced... your running one side richer then the other... as far as drilling your jet... you need to by the feller gauges and push them through... they sell round ones at sears right next to the flat feeler gauges Quote
ban1 Posted May 1, 2007 Author Report Posted May 1, 2007 bothsides have oil coming out, just the left side appears to have more. does this mean its rich, when i put the new carbs on i adjusted the slides so they moved at the same time, is this not the way to sink carbs. and i know what size i drilled the holes what i dont know is what size of jets this would make it.(i know they are bigger than the 300 mains that i had in them.alot bigger) they are makuni 28mm flat slide carbs. ken Quote
Bansh-eman Posted May 1, 2007 Report Posted May 1, 2007 it is impossible to sync your carbs by eye... you can get it close but not synced... get a carb sync tool from jeff at FAST you will get it balls on... as far as the jets go i cant help you out there... mikunis and keihens are differant sizes... you shouldnt need alot bigger then 300s maybe 320s... when i ran stockers i had pipes filter reeds and lid off and ran 320s at sea lvl... cant see your being much off from that... Quote
