1966nova Posted April 16, 2007 Report Posted April 16, 2007 i have a 01 banshee with reed valves vitos and fmf pipes very mild port work all rest is stock with just k/n filter with no holes cut in the box? should i cut holes in the box? im very new to banshees it has stock jets also im in dallas tx..... i would like some advice on which jets????? thanks greg Quote
1966nova Posted April 16, 2007 Author Report Posted April 16, 2007 i forgot also stock head 20 thous milled..... Quote
Screaming Yellow Zonker Posted April 17, 2007 Report Posted April 17, 2007 with the exhaust and port job you definitely need to increase your jets. you can pick up the kit at your local MX performance shop for about $70. it should come with new main and pilot jets and needles. If you are running an air box I would not run a lid. the holes will help increase the air flow to the filter. Quote
mpbanshee Posted April 17, 2007 Report Posted April 17, 2007 Yes, you need to rejet! Personally, I would not waste money on a "jet kit". Your stock needles and pilots shoul be ok (may need a 27.5 pilot though). Unless you frequently ride in water, I would get a filter adapter, and ditch the airbox lid. You will probably need to be somewhere between 280-310 on the main jets. Do a plug reading to dial it in perfectly. Quote
