All I can really say about this quads is that it kicks a$$ :biggrin: No but seriously this shee is F-A-S-T!
It's a +4mm 370, Crank has been trued and welded, ported cylinders, milled head, full FMF system, the list goes on and on. Below is a complete list with mods
Will trade for a TRX 450 preferably and might throw in some cash and could travel! I would though be interested in any 450 or Raptor 660 modified or 700.
Number: 231 420 4778
Email: [email protected]
Chassis
Adjustable caster/camber
Chromoly A-Arms 2+ wider/2+forword
Chromoly round housing swing arm
Chromoly tie rods with hiem ends
Chromoly desert bumper
Denton steering stabilizer
AC aluminum nerf bars with nets
AC aluminum rear grab bars
Answer alumalite bar
Pro design tether
MSR easy pull cultch lever
MSR brake lever
NACS billet dog bone
NACS billet rear caliper cover
Braided brake lines front & rear
Works triple rate front shocks
Denton revolver rear shocks with eibach spring
Cascade chain guide & roller
Dura Blue + 4 axle
Billet sprocket mount
Pipe hangers& connectors
Champion bead locks with grooved terftamers
Douglas reinforced rims with grooved parelli radials
New OEM plastic
Cascade complete seat
Motion pro twist throttle
Custom Grill Insert
Motor 370 long rod
Trued & welded crank with +4 mm hot rods
Ported cylinders
Case ported
Milled head
Vitos boost ported pistons
V-force reeds
Reed spacers
30mm mikunis bored to 32mm with vitos jet kit
Toomey 2 into 1 air filter kit
Uni 2 stage filter
Outerwear
Pro design billet adjustable timing plate
FMF fatty Pipes
FMF power core silencers
Shift star mod
Would you be willing to travel at all for a damn nice 660?? I have a buddy that is looking for a Banshee, his name on here is JPS.. He has a 01 Raptor that is real nice.. The trans has been fixed/updated(01 had the weak trans).. Powder coated frame, fullbore plastic and quite a few other goodies.. Only problem is we are out in Colorado :confused: So Iam just curious how far you would travel.. Thanks
RIPPEN
  • 2 weeks later...
