Hummah2 Posted April 9, 2007 Report Posted April 9, 2007 I re-built my whole banshee and While I was working on the motor and mounting everything back up my friend was working on the wiring harness and I thought we had the wires for the kill switch hooked up correctly but I guess not. Can anybody describe which wires I need to run the wires from the kill switch too? Im assuming to hook up the key you just need to run the wires to the same spot as for the kill switch since it does the same thing. If anybody can look at their shee and let me know or knows of the top of their head please let me know!!!!! Thanks. post it or email me at [email protected] Quote
Bansh-eman Posted April 9, 2007 Report Posted April 9, 2007 ok lets do this... try removing the key alltogether... to do this trace the 4 wires from the key down to the plug under your plastics... unplug it and cut the bottom plug ... it has two wires... splice those two wires together and seal them off with some liquid tape ... you can get it at walmart... im not a fan of wrapping electrical tape casue when it gets hot it tends to lossen up and come off.. now as far as your kill switch goes... there is only two wires... you have a black wire with white on it that goes into your cdi... your kill switch has the same... plug those together...then your switch should also have a ground... depending on what switch your running it could be any color ... mines green. im using a cr250 kill switch... ground it out and you should be good... Quote
