Is there any way to tell the size of the bore without taking the engine all the way apart? Can I just pull the head off and tell?
Stock? Cubs?
it is stock just trying to find out the size of my pistons without tearing it down yet
take off the head,. turn the motor slow to bring one piston to the bottom and stick a bore gauge or really good calipers in there. Bore gauge is much better. Check both cyclinders because once in every great while youll come across cylinders of 2 different sizes.
Thanks man, I was thinking I would have to do that, but wasn't sure.
A good old vernier will do the trick. :geek:
