Is there any way to properly fix a cracked subframe?.. one side completely snapped about 5 inches from the end..right between the first and second mounting hole for the grab bar... the other side is stressed pretty bad ...i probally could snap it off with my hand .... I have already had this problem once and had it repaired but either it was a bad weld job or im bad at wheelies .. I would like to get this fixed right for the last time ...any suggestions?
Fix it, weld in braces and stop slamming it......
Before you weld it, can you clean up the inside of tube ends & fit a sleeve inside. This will add more strength.
