dtzalba450r Posted March 31, 2007 Report Posted March 31, 2007 This is some stuff left over from an earlier part out. There is some new parts mixxed with some older stuff. All prices are best offer and doesn't include shipping. I will post pictures of everything later. If there is something you want make sure to ask because I may have it. Thanks! stock carbs with the tors system and cable $65.00 (2000) rear shock $45.00 (2000) brake pedal/master cylinder/resevoir $45.00 (2000) fmf fatty pipes one pipe has a dent and the canisters are little rough $135.00 complete stock pipes $65.00 (2005) sprocket hub and sprocket $30.00 (2000) brake hub/rotor $30.00 (2000) rear linkage $25.00 (2000) swingarm $65.00 (2000) foot pegs $20.00 (2000) airbox lid $12.00 (2005) stock air filter $8.00 (2005) coil $28.00 (2000) lower engine mounts $22.00 (2000) front master cylinder from a yfz450 w/ lever $40.00 (2006) tail light mounting bracket $12.00 (2005) Quote
xsinnerx Posted April 1, 2007 Report Posted April 1, 2007 This is some stuff left over from an earlier part out. There is some new parts mixxed with some older stuff. All prices are best offer and doesn't include shipping. I will post pictures of everything later. If there is something you want make sure to ask because I may have it. Thanks! stock carbs with the tors system and cable $65.00 (2000) rear shock $45.00 (2000) brake pedal/master cylinder/resevoir $45.00 (2000) fmf fatty pipes one pipe has a dent and the canisters are little rough $135.00 complete stock pipes $65.00 (2005) sprocket hub and sprocket $30.00 (2000) brake hub/rotor $30.00 (2000) rear linkage $25.00 (2000) swingarm $65.00 (2000) foot pegs $20.00 (2000) airbox lid $12.00 (2005) stock air filter $8.00 (2005) coil $28.00 (2000) lower engine mounts $22.00 (2000) front master cylinder from a yfz450 w/ lever $40.00 (2006) tail light mounting bracket $12.00 (2005) I'll take the rear shock, pm me with payment method. Quote
xsinnerx Posted April 1, 2007 Report Posted April 1, 2007 This is some stuff left over from an earlier part out. There is some new parts mixxed with some older stuff. All prices are best offer and doesn't include shipping. I will post pictures of everything later. If there is something you want make sure to ask because I may have it. Thanks! stock carbs with the tors system and cable $65.00 (2000) rear shock $45.00 (2000) brake pedal/master cylinder/resevoir $45.00 (2000) fmf fatty pipes one pipe has a dent and the canisters are little rough $135.00 complete stock pipes $65.00 (2005) sprocket hub and sprocket $30.00 (2000) brake hub/rotor $30.00 (2000) rear linkage $25.00 (2000) swingarm $65.00 (2000) foot pegs $20.00 (2000) airbox lid $12.00 (2005) stock air filter $8.00 (2005) coil $28.00 (2000) lower engine mounts $22.00 (2000) front master cylinder from a yfz450 w/ lever $40.00 (2006) tail light mounting bracket $12.00 (2005) payment sent for the rear shock, thanks a lot!! Quote
jerseyboy Posted April 1, 2007 Report Posted April 1, 2007 do you still have the carbs would you do 65 shipped to n.c? Quote
dtzalba450r Posted April 1, 2007 Author Report Posted April 1, 2007 do you still have the carbs would you do 65 shipped to n.c? I still have the carbs and yes I will take $65.00 shipped send payment to [email protected] Quote
Strawboss Posted April 2, 2007 Report Posted April 2, 2007 Will you take $15 for the airbox lid shipped to 53048? Quote
dtzalba450r Posted April 2, 2007 Author Report Posted April 2, 2007 Will you take $15 for the airbox lid shipped to 53048? $17.50 and its urs. Quote
dtzalba450r Posted April 4, 2007 Author Report Posted April 4, 2007 ttt rear shock sold, everything else make an offer Quote
