One other thing, that CDI is getting the finger on this one. Running for several minutes before heating up and failing. that is the right amount of time for a CDI issue. Generally, stators will heat and fail in 1-2minutes. You can them check the stator real quick while hot and generally find a ground loop short. With 10-12 runs before it craps out, I would lean damn hard on that CDI. We have had them run for 15-20 min before they show signs of failure. Just swap and try it. Simple, simple.
Brandon
I did that im actually still running my buddys CDI off his bike, his bike runs great and flawless with my CDI on his, i dont think is the oil issue u speak of cause the plugs look absolutely fantastic, i just got to have a bad stator... well were those numbers good?, but im going to try a few things tomorrow, im going to try a whole new stator and see what happens, if i have to ill replace everything.
You tryin hands stator or u need that extra of mine? I might be able to sneak off out there for a bit but dunno how long, holler when u figure out what time ur goin to tinbucktu.
Brandon
That sounds pretty reasonable. I fingered the stator first because I have actually had that happen to me a few times. I have never had a CDI unit go bad. :thumbsup:
