KlotzBanshee Posted March 22, 2007 Report Posted March 22, 2007 Naval Jelly. no its not from your belly button. :: its not??? Damn it...here I thought I had an endless supply :: ...too much lint in it anyway :shrug: Quote
Flanagans twin Posted March 22, 2007 Report Posted March 22, 2007 not too bad of rust- lime a way or clr or something of that line, kind of lighter in power really rusted/pitted badly- use some high power/commercial grade rust remover like must for rust n what not like that, mine were pitted horribly and look like a$$ and i used a brush, scotch brite scrub pad, and soaked the pipes and pad n must for rust, and rubbbed, not even hard, soon the chemical was brown, took hot water to it, rust all gone, took a mothers buff ball and drill with some polish and buffed it nicely for a while n then polished them by hand, almost new! they shine, not as good as brand new chrome but way damn better than pitted/rust! Quote
brugal Posted March 23, 2007 Report Posted March 23, 2007 Im glad this was asked cuz I have some rust on my pipes.Ive seen the naval jelly,now I know to get some. Thanks. Quote
highroller355 Posted March 24, 2007 Report Posted March 24, 2007 ive used never dull its a cloth that comes in a can then polish them real good with mothers or something Quote
trail rider Posted March 24, 2007 Report Posted March 24, 2007 you can take some cola and aluminum foil (the stuff that you can cook with) and it will remove rust and polish and clean your chrome at the same. seen this on mythbusters on the discovery channel and I had to try it my self and it really does work pretty good. just pour some coke on the rust and let it set for a few seconds and then scrub away at it with the aluminum foil Quote
ClimbAnyHill Posted March 24, 2007 Report Posted March 24, 2007 All surface junk can be cleaned up. I used the cordless drill with sanding disk, wire disc for the heavy junk and smooth it out with sanding disk. Nothing to it. A bit of work & you'll get down to bare metal pretty fast. Quote
sgt seth Posted March 24, 2007 Report Posted March 24, 2007 I have the Trin4's, so all I did was went an picked up some tarnish remover and CLR from walmart and am using steel wool to buff it out. Haven't gotten a chance to start yet but if this doesn't work will be using naval jelly. Quote
