Hey Guys,
It's finally time, I'll be putting the RZ in my 'shee tomorrow and I've got a few questions.
1)Do the powervalves have a home position? Will the controller find home? Or, can I determine home in the way I set them and therefore determine if they'll hit more in the bottom or top rpms? I'm running a battery eliminator so they won't cycle before startup.
2)The most popular question on here....any jetting recommendations? I'm running stock 'shee carbs with 280 mains at the moment and stock reeds for now (possibly the RZ reeds if you think they'd perform better). I have a feeling they are going to be way lean. For the time being I'll be running PT High Revs and no airbox.
3)I kind of want to run a hone through the cylinders real quick, they have a little bit of glazing. If I do should I go ahead and buy new rings? About honing, anybody care to give me some technique advice? What type to use? What should the end result look like?
Thanks guys!
Matt
