pokeatyou2 Posted March 16, 2007 Report Posted March 16, 2007 (edited) what is the go with the little pits i have on top of my left piston please help? its only about 10 hours old Edited March 16, 2007 by pokeatyou2 Quote
FireHead Posted March 16, 2007 Report Posted March 16, 2007 Do you mean the piston on the right of the photograph? It's either detonation or you had some dirt or something in there. Quote
pokeatyou2 Posted March 16, 2007 Author Report Posted March 16, 2007 Do you mean the piston on the right of the photograph? It's either detonation or you had some dirt or something in there. yer sorry right my bad\ Quote
blowit Posted March 16, 2007 Report Posted March 16, 2007 yer sorry right my bad\ K, if you can offer a MUCH closer pic of the piston or tell me if the pits are elevated on the edges around the pit? Are the pit centers shiny or very dull? I need to know the motor and head setup too. I am leaning on pre-ignition and not detonation. The random pattern would be WAY before TDC. Either that or you threw a hand full of sand in it. Also inspect the head for damage. If it is FOD, it will have damage in the head as well. If you are running wimpy fuel in a tuned up banshee, there you go. Brandon Quote
blowit Posted March 16, 2007 Report Posted March 16, 2007 K, if you can offer a MUCH closer pic of the piston or tell me if the pits are elevated on the edges around the pit? Are the pit centers shiny or very dull? I need to know the motor and head setup too. I am leaning on pre-ignition and not detonation. The random pattern would be WAY before TDC. Either that or you threw a hand full of sand in it. Also inspect the head for damage. If it is FOD, it will have damage in the head as well. If you are running wimpy fuel in a tuned up banshee, there you go. Brandon Did you kill your engine before the rebuild and forget to clean out the pipes??? That'l Do'r Brandon Quote
AnCieNt1 Posted March 16, 2007 Report Posted March 16, 2007 that looks more like a trash problem to me.. Quote
pokeatyou2 Posted March 16, 2007 Author Report Posted March 16, 2007 that looks more like a trash problem to me.. what do you mean by trash problem? Quote
pokeatyou2 Posted March 16, 2007 Author Report Posted March 16, 2007 (edited) Did you kill your engine before the rebuild and forget to clean out the pipes??? That'l Do'rBrandon nar i didnt kil the engine i done the rebuild for porting reasons i have a head with 21cc domes +4 timing dune port . boyeson power reeds mod quad intake standard carbs dual stge foam filter with power lid and dmc alien pipes if it was detonation wouldnt it be on both pistons and yes the dome has little pits aswell also i running 98 ron octance fuel best i can get on pump in OZ Edited March 16, 2007 by pokeatyou2 Quote
FireHead Posted March 16, 2007 Report Posted March 16, 2007 what do you mean by trash problem? Trash = dirt or metal that foung it's way into the cylinder. :thumbsup: Quote
pokeatyou2 Posted March 16, 2007 Author Report Posted March 16, 2007 nar i didnt kil the engine i done the rebuild for porting reasons i have a head with 21cc domes +4 timing dune port . boyeson power reeds mod quad intake standard carbs dual stge foam filter with power lid and dmc alien pipes if it was detonation wouldnt it be on both pistons and yes the dome has little pits aswell also i running 98 ron octance fuel best i can get on pump in OZ Quote
pokeatyou2 Posted March 16, 2007 Author Report Posted March 16, 2007 also should i be tearing it down again becasue of this? Quote
FireHead Posted March 16, 2007 Report Posted March 16, 2007 also should i be tearing it down again becasue of this? If it were me I wouldn't bother. Whatever did that is probably gone by now. It could have easily been detonation that occurred when you overheated the bike. :shrug: Quote
blowit Posted March 16, 2007 Report Posted March 16, 2007 If it were me I wouldn't bother. Whatever did that is probably gone by now. It could have easily been detonation that occurred when you overheated the bike. :shrug: Firehead, I have never seen a piston with detonation damage in a random fashion like this. I am sure you will tell me otherwise but I think he done told us it was FOD though. I would run it as well. Damage probably occurred in the first 5 seconds of it's life. Damage is done, move on. Just hope it did not get in the crank bearings and shorten their life. B Quote
AnCieNt1 Posted March 16, 2007 Report Posted March 16, 2007 what made you tear it down to begin with? i still think it was something in the motor when you put it back together either something that wasnt cleaned good or something that got in it when it was apart. if it was running fine im like firehead just put it back together if it was running fine.but that is really up to you because its your motor.. Quote
pokeatyou2 Posted March 16, 2007 Author Report Posted March 16, 2007 (edited) what made you tear it down to begin with? i still think it was something in the motor when you put it back together either something that wasnt cleaned good or something that got in it when it was apart. if it was running fine im like firehead just put it back together if it was running fine.but that is really up to you because its your motor.. i took the head off because i was advise to my a few people on here to check the orings of my head when i had an over heating problem also what is FOD? Edited March 16, 2007 by pokeatyou2 Quote
