BenBB Posted March 16, 2007 Report Posted March 16, 2007 I got these cleaned up and ready to go, I'd like to sell the (stock) a-arms as a set of all four along with the aluminum DG a-arm guards, and the shocks as a pair, but I'll split 'em up if anybody needs something specific. These are all off my son's 2001 Banshee, look like they are in decent shape with normal scratches/scrapes, but all four balljoints are tight and all the boots are intact. All the bushings look good with the exception of the lower LH a-arm, one of the plastic bushings is kinda chewed on the outside but the bearing surfaces are good and all four a-arms are TIGHT when installed, no play. I bought this Banshee used and it looks like the RH upper and lower a-arms are the factory '01s and the LH upper and lower a-arms are older...I suspect one of the original owners destroyed both RH a-arms and replaced them with used ones. Anyway the shocks are good, no bends or leaks and the white springs are in pretty good shape, only a couple chips from rocks. The tie rods look straight, rolling them on a flat surface they don't wobble. I'm looking for $125 SHIPPED via UPS Ground in the lower 48 for the a-arms and guards. I'd like to get $50 SHIPPED for the pair of stock shocks. Otherwise, say $165 SHIPPED for everything in the pic, or $30 SHIPPED per a-arm and $30 SHIPPED for the guards alone. Quote
