yfz450killer Posted March 14, 2007 Report Posted March 14, 2007 Located on ebay below. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...3394&rd=1,1 Reserve is $8500.00 2000 Yamaha Drag Banshee 10mm Twister Alcohol Motor built by Twister Crank Shaft Company in Boring, OK. Their web site is www.twistercrankshaft.com Bike has around 130-140 hp to the ground. Dyno-ed at Little Sahara OK and they could not keep it on the dyno to fully see what it could do. Here is what the bike is and has done to it. 2000 Banshee with frame powder coated purple, Plastics race cut and custom paint job. Seat is custom stiched with extra padding to help keep you on it.(does not help when the bike will jerk you off of it). 10 mm Twister Billet Crank, 510CC Twister Head full drag port, Lightend flywheel, Twister Clutch Basket, Twister High output ignition w/ seperate coils, Twister billet clutch case, Billet flywheel case, V force reeds, Lection Carbs set up for Alcohol, Out of frame drag pipes with silencers, Pingle Valve, Lock-up clutch, Dunable 2-5 override, Marvin Shaw competition Billet Shocks, 10 inch lonestar swing arm with round carrier, 40 mm Aluminum drag axle adjustable with billet hubs, 13X22X11-8 paddles Hauler Extremes, Skat Trac Smoothies on the front, Twist throttle, MSR Clutch lever, Oneal bars, Aluminum steering stem w banshee engraved, Aluminum cap on front brake, KillSwitch, Chrome Wheelie bar, Wave Rotor back brake, Billet coolant bottle holder. OVER $16000.00 INVESTED AND $9000.00 IN THE MOTOR ALONE. Bike has been run on Benol 2 stroke oil and is setup for Alcohol. As you can see no expense was spared. The bike runs strong and runs perfect. We are located in Dallas, TX and can meet you within a 200 mile radius. There will be a charge of .25 per mile to cover gas. Call 214 725-6372 with questions. Bike was way more than expected. Quote
holeshot2 Posted March 14, 2007 Report Posted March 14, 2007 Located on ebay below. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...3394&rd=1,1 Reserve is $8500.00 2000 Yamaha Drag Banshee 10mm Twister Alcohol Motor built by Twister Crank Shaft Company in Boring, OK. Their web site is www.twistercrankshaft.com Bike has around 130-140 hp to the ground. Dyno-ed at Little Sahara OK and they could not keep it on the dyno to fully see what it could do. Here is what the bike is and has done to it. 2000 Banshee with frame powder coated purple, Plastics race cut and custom paint job. Seat is custom stiched with extra padding to help keep you on it.(does not help when the bike will jerk you off of it). 10 mm Twister Billet Crank, 510CC Twister Head full drag port, Lightend flywheel, Twister Clutch Basket, Twister High output ignition w/ seperate coils, Twister billet clutch case, Billet flywheel case, V force reeds, Lection Carbs set up for Alcohol, Out of frame drag pipes with silencers, Pingle Valve, Lock-up clutch, Dunable 2-5 override, Marvin Shaw competition Billet Shocks, 10 inch lonestar swing arm with round carrier, 40 mm Aluminum drag axle adjustable with billet hubs, 13X22X11-8 paddles Hauler Extremes, Skat Trac Smoothies on the front, Twist throttle, MSR Clutch lever, Oneal bars, Aluminum steering stem w banshee engraved, Aluminum cap on front brake, KillSwitch, Chrome Wheelie bar, Wave Rotor back brake, Billet coolant bottle holder. OVER $16000.00 INVESTED AND $9000.00 IN THE MOTOR ALONE. Bike has been run on Benol 2 stroke oil and is setup for Alcohol. As you can see no expense was spared. The bike runs strong and runs perfect. We are located in Dallas, TX and can meet you within a 200 mile radius. There will be a charge of .25 per mile to cover gas. Call 214 725-6372 with questions. Bike was way more than expected. nice bike and good luck with sale Quote
