tyguy Posted March 12, 2007 Report Posted March 12, 2007 does anyonye know what a good gearing is for a blaster? i have power but its just motor and no go, its got the 240 big bore, its stock gearing 14/40. any opinons? new clutch and its perfect Quote
tyguy Posted March 12, 2007 Author Report Posted March 12, 2007 sorry, wasnt sure where to go bc this is a banshee forum, but everywhere theres a banshee theres a blaster. :biggrin: Quote
tyguy Posted March 12, 2007 Author Report Posted March 12, 2007 so do you think a 15/38 would pull to hard? ive got alot of rev, just no go. Quote
92 banshee Posted March 12, 2007 Report Posted March 12, 2007 so do you think a 15/38 would pull to hard? ive got alot of rev, just no go. just do 14/38......the 15 tooth front sprocket takes some case grinding to get it on and then when its on people say its not safe...but it would probably go around 70mph with 20 inch tires depending on how high your engine can rev Quote
nunyabinness Posted March 12, 2007 Report Posted March 12, 2007 you don't have to grind the case for a 15 tooth front sprocket. you have to grind the stator cover. Quote
jlsparky7 Posted March 12, 2007 Report Posted March 12, 2007 I wouldnt grind anything. Just change the rear sprocket.... Quote
tyguy Posted March 13, 2007 Author Report Posted March 13, 2007 (edited) ok thanks guys ill order a 38 rear than, thanks even tho its not a banshee. Edited March 13, 2007 by tyguy Quote
