Ace_Cobra Posted February 25, 2007 Report Posted February 25, 2007 hi folks, today i've do a ride with my shee. i've got some problem... it started sputtering at low rpm. It was bogging down when I hit the gas but ran ok at high rpm...after a while (need to go back at home..) the motor stalled... 5-6 time on the kickstart and it running back but still sputtering at low rpm..i've put my backup spark plug, after it was perfect on low and high rpm..after 1 miles, the problem have come back and stalled again :: ... my friends pulled me and after a while, it started again...and restaller withing few miles.. and it never restarted... it have spark.. it was running good in high rpm the plugs color was perfect thanks to help me ! its a '87 banshee with FMF gnarly pipe, running 290 main jets (its cold here) (sorry for my bad english, i do my best ) Quote
JET 99 Posted February 25, 2007 Report Posted February 25, 2007 as far as asking jetting questions????????????? plugs can look ok but there are three diffrent circuits on your carbs.. so it can run good at half throttle but run crappy at wide open throttle idle crappy then clean out 1/2 throttle and up... in jetting and exhaust forum you will find all the info you can use and more.................. Quote
Ace_Cobra Posted February 25, 2007 Author Report Posted February 25, 2007 the bike was running like a charm before... you think it may be dust in the carb? Quote
dajogejr Posted February 25, 2007 Report Posted February 25, 2007 You said "backup Plug"... Get two fresh plugs. What are all your mods? What temp and elevation do you ride at? How fresh is the gas in the bike... Quote
Fastrat Posted February 25, 2007 Report Posted February 25, 2007 I would do a comp. ck and look into the carbs. GL Quote
Ace_Cobra Posted February 26, 2007 Author Report Posted February 26, 2007 i have solved the problem, the gas line was frozen :: thanks ! Quote
JET 99 Posted February 26, 2007 Report Posted February 26, 2007 i have solved the problem, the gas line was frozen :: thanks ! damn son you riddin in antarctica?????????? you said it was cold, but freeze the gas line........ :miner: :miner: :miner: :beer: Quote
Fastrat Posted February 26, 2007 Report Posted February 26, 2007 lol, frozen gas line....damn.. Quote
Ace_Cobra Posted February 26, 2007 Author Report Posted February 26, 2007 its winter here maybe there were humidity in my mixt tank ? anyway, i'll put some gasline for the next week Quote
ojcool Posted February 27, 2007 Report Posted February 27, 2007 Puts some drygas in it (you don't need much). You have water in your fuel. Drain your fuel bowls. Gasoline freezes at 97 degrees below 0. Your not getting anywhere close to that. Put some drygas into your gas can too, that's where the moisture is most likely coming from. Quote
