I bought my Banshee with mods below:
K&N Pod filters
Cool head with 18cc domes
T5s
+4 timing plate
It ran awesome and when I finally tore into the carbs I found 300 main jets, stock pilots, stock needles (forgot where they were at though).
Now, I
Edited by brodysblanshee
I was running 380 mains, stock pilots, needle 5th clip in my stroker w/ a mx port, sea level, 50-80 degrees out...w/ ptr mids...The T5's like a little more fuel, but your humidity is higher as well as your temps, so you should be close depending on any porting.....I'd start there and work down. I originally started w/ 330's and my plugs were white.......(scary white)
