i am going to finish taking it apart tonight and i will double check everything i have done so far. by the way what is that pancake bearing. and if it helps that much where can i get 1.
A pancake bearing is an aftermarket assembly that replaces the adjuster in your clutch pressure plate. It is basically a flat, caged roller bearing. :thumbsup:
Might want to check your clutch adjustment. Check the arrows on the clutch pull lever and on the case. Should line up or be a little bit towards the stator side with the slack out of the clutch lever. You can adjust that with the nut and philips head screw in the outer clutch hub. Jeff at F.A.S.T. sells the pancake bearings. Give him a call.
thanks guys you have all been a big help it is great that you all take time to help a fellow rider i have not had the time to finish checking everything. (family) i hope to do it teusday night i will let you know how it goes. please keep the advice coming i could really use it
ok all i pulled the clutch ball it it is fine i checked the rod evrything seems to move fine. i think i am going to put a new clutch in it and change the cable while i am at it. the guy i bought it from gave me a new one anyway he said the old one was stetched (i never had a problem). i will post when i am done to let you know if she works.
