03portedshee Posted January 26, 2007 Report Posted January 26, 2007 I have a 2-5 override tranny, cpi out of frame drag pipes with silencers chrome, and a banshee frame that has been lightened. PM me with any interest. Thanks Quote
gipperz Posted January 27, 2007 Report Posted January 27, 2007 Is the overide tranny duneable? How much? Does that meen you have to use the clutch from first to second and then you can shift clutchless up to fifth and use the clutch going into sixth? Just trying to get this straight in my head. I want to go to a overide thats why I'm asking. Wondering if this would fit my needs. Quote
banshee332 Posted January 27, 2007 Report Posted January 27, 2007 Is the overide tranny duneable? How much? Does that meen you have to use the clutch from first to second and then you can shift clutchless up to fifth and use the clutch going into sixth? Just trying to get this straight in my head. I want to go to a overide thats why I'm asking. Wondering if this would fit my needs. 2-5 means there is no first gear. Quote
mattbc Posted January 27, 2007 Report Posted January 27, 2007 2-5 means there is no first gear. No 2-5 means that only 2nd-5th are cut to use w/o the clutch. First gear is still useable and yes you have to use the clutch to go from 1st to 2nd. 6th gear can still be there... some guys cut the tit of the shift star so you cant get in 6th, some cut the tit and take the gear clear out, or you can leave it in and and use the clutch to shift into 6th. depends on how the guy had the tranny set up. Quote
03portedshee Posted January 28, 2007 Author Report Posted January 28, 2007 No 2-5 means that only 2nd-5th are cut to use w/o the clutch. First gear is still useable and yes you have to use the clutch to go from 1st to 2nd. 6th gear can still be there... some guys cut the tit of the shift star so you cant get in 6th, some cut the tit and take the gear clear out, or you can leave it in and and use the clutch to shift into 6th. depends on how the guy had the tranny set up. It is a duneable tranny. It is a 2-5 override tranny. You still have 1st gear like Matt said but it does not have 6th gear. 6th gear is not needed in a 300 foot race for the most part. Let me know if interested. Ill take 350 shipped to your house. thanks Quote
gipperz Posted January 28, 2007 Report Posted January 28, 2007 It is a duneable tranny. It is a 2-5 override tranny. You still have 1st gear like Matt said but it does not have 6th gear. 6th gear is not needed in a 300 foot race for the most part. Let me know if interested. Ill take 350 shipped to your house. thanks Thank you for responce. I'll have to pass on that, not due to the price but I need sixth gear for when I travel down dirt roads. Free bump. Quote
Guest Blznokie Posted January 30, 2007 Report Posted January 30, 2007 I have a 2-5 override tranny, cpi out of frame drag pipes with silencers chrome, and a banshee frame that has been lightened. PM me with any interest. Thanks pm sent hit me back Quote
sheefreak Posted January 30, 2007 Report Posted January 30, 2007 Pictures of override? Who cut it? How much has it been used? Quote
ls409 Posted January 30, 2007 Report Posted January 30, 2007 Pictures of override? Who cut it? How much has it been used? you got any pics of the frame and how much thanks Quote
bansheepartsguy Posted February 27, 2007 Report Posted February 27, 2007 got any pics of the pipes. Are they big bore or small bore? How do they rate on a scale of 1-10 as far as condition? Quote
Crazy05 Posted February 28, 2007 Report Posted February 28, 2007 i'm interested in the overide. Location? Quote
03portedshee Posted March 1, 2007 Author Report Posted March 1, 2007 i'm interested in the overide. Location? Miami Oklahoma let me know if you want it i will send it to you as soon as the payment is received. Thanks Quote
03portedshee Posted March 1, 2007 Author Report Posted March 1, 2007 (edited) got any pics of the pipes. Are they big bore or small bore? How do they rate on a scale of 1-10 as far as condition? Pipes are sold. Here is what i have left. 2-5 override tranny 350 Axle 75 clutch assembly 100 frame 200 cdi 25 front spindles 40 rear hubs 40 rear shock 40 coil 25 wiring harness 40 rear sprocket hub 20 13 tooth sprocket 10 44 tooth rear sprocket 10 upper and lower cases kickstart gear 25 kickstart lever 30 seat 30 throttle assembly 20 pro design teather 25 Edited March 1, 2007 by 03portedshee Quote
strokrbanshee1 Posted March 2, 2007 Report Posted March 2, 2007 free bump for a good guy... is that 44 rear steel??? I need lightweight stuff what ya got???lol... Quote
