2strokeBear Posted January 24, 2007 Report Posted January 24, 2007 I want to get a cool head and i am wondering what size domes to get with my setup. I live at sea level and i have and 06 banshee with pipes and K&N filter. I ride mostly pits and trails. Advice needed. Quote
Animalman294 Posted January 24, 2007 Report Posted January 24, 2007 Contact Noss and he will set you up with a Noss head and tell you what domes to get. He goes by dlnoss on here and is a great guy to work with..................... Quote
87sheerips Posted January 24, 2007 Report Posted January 24, 2007 yea, id say 21 or 20 to keep things simple, plus you can run pump gas. Plus, you will have less compression which will give you a little more reliability. My .02.... Quote
2003LimitedBanshee Posted January 24, 2007 Report Posted January 24, 2007 Just a side note, but I kick 190+psi on stock bore/port at sea level. Mods below. With timing, NOT Pump gas FRIENDLY. Quote
Snopczynski Posted January 24, 2007 Report Posted January 24, 2007 (edited) I have 20cc domes on a stock motor, gauge says it is 168psi. Approximate Cranking Compression These pressures are estimates based on fresh stock bore, piston, porting, and deck height. It is recommended to check your compression after installation. Sea Level 1000' 2000' 3000' 4000' 5000' 18cc 197 178 171 170 165 145 19cc 183 167 160 158 152 137 20cc 169 156 149 146 140 129 21cc 156 145 138 134 128 121 stock 130 125 118 112 106 100 Edited January 24, 2007 by Snopczynski Quote
