I had a piston come apart and had to remove the engine for repairs. The vent line that comes out of the right side of the crankcase is routed to the rear through a 'T' fitting and then goes to a white 90 deg. nipple. The nipple is still attached to the hose and I didn't notice where it came from. Does anybody have a clue where it goes?
its 3 hoses 1 from the rear of the motor,by the where the motor mounts.2 from the clutch side cover.3 to a vent hose thats tied up behind the radiador,on your right side. :whistling:
Thanks for the reply. I didn't mention the front hose as I wasn't sure where it went to. I noticed a white plug on the top of the cases at the rear mount. Is it that the place or is it lower, below the mount?
thats the one....... :thumbsup:
