hey guys just just putting my engine back together at the moment ive got a hot rod crank for it. Ive noticed that the factory crank has pins which locate in the casings on the bearings. The hot rod crank has one pin on the clutch side but no other ones. Have they done away with this design now? ive noticed the hot rod crank has o rings aswell.
any1 know what im talking about?
yes, so whats your question? both bearigs should have a small dowel pin to keep the bearing from spinning.then you should have the c clip halfs for each side as well
Edited by Bansh-eman
