banshee332 Posted January 7, 2007 Report Posted January 7, 2007 I was thinking about buying a bottom end off my buddy. Its a blaster bottom end with a 6mill stroker. I am looking for an after market cylinder that will work with this. Do you guys have any websites or anythign that I could check out? Quote
blaster668 Posted January 9, 2007 Report Posted January 9, 2007 http://www.ctracing.com/blaster.htm I think CT is the only place that makes aftermarket cylinders, but 240's are common on the stock cylinders also. The Sonic cylinder is quite a bit better though, the port layouts are very similar to Honda 250R's and it uses a 250 intake and reed setup. Vitos and some other places may have cylinders also...I've been away from Blasters for a couple years. Another option is to build a liquid cooled power valve motor. The parts are available from Yamaha outside the US. I believe the bike that used this setup was an rd200 I could be wrong on that though. Some of the people that were building them were getting good results though. Quote
nunyabinness Posted January 9, 2007 Report Posted January 9, 2007 www.CPCustoms.com has some good blaster motors. also projectblaster.com has a real good motor. i haven't used either one but i have heard some real good stuff about them. there was a couple of good blaster forums but i think they both closed down. barrymaxx might have some good info for you. he's pretty knowledgeable on blasters. Quote
