kojack Posted January 4, 2007 Report Posted January 4, 2007 anyone know if the tors kit works with a stock throttle cable? Quote
moneybags Posted January 4, 2007 Report Posted January 4, 2007 My TORS elem kit came with its own cable. If you just unplug the wire from the black box you should be good. Quote
kojack Posted January 4, 2007 Author Report Posted January 4, 2007 its unplugged already. I just have the crappy tors housing sitting on top of my carbs getting in the road. Vitos sells carb caps without the cable. Thats why im wondering if i can buy just the caps and not the cable. Quote
dajogejr Posted January 4, 2007 Report Posted January 4, 2007 You MUST have the cable... It is shorter due to the TORS on top the carbs being removed.... Buy the whole kit, cause you're gonna need the drill, tap and idle screw kits, too. You need to install the idle screw kits because the TORS adjusters on top of the carbs handle idle speed as well...till they're removed, anywho... Magic, Vitos...and a bunch others sell the COMPLETE Removal kit, with everything you need. This guy has 'em... http://www.farmandsandtoys.com/partdetail.asp?partid=123 Quote
kojack Posted January 5, 2007 Author Report Posted January 5, 2007 You MUST have the cable...It is shorter due to the TORS on top the carbs being removed.... Buy the whole kit, cause you're gonna need the drill, tap and idle screw kits, too. You need to install the idle screw kits because the TORS adjusters on top of the carbs handle idle speed as well...till they're removed, anywho... Magic, Vitos...and a bunch others sell the COMPLETE Removal kit, with everything you need. This guy has 'em... http://www.farmandsandtoys.com/partdetail.asp?partid=123 thats the info i was lookin for. thanks Quote
