ehenn34 Posted December 29, 2006 Report Posted December 29, 2006 whats up fellas, need help on how to change my throttle cable.. have a 2000 shee. thanks Quote
Rustbag Posted December 29, 2006 Report Posted December 29, 2006 Phililps screwdriver is pretty much all you need. You have to unscrew the carb caps to be able to look down in the tops of the slides to unscew the little metal thingy that holds the cable to the carb slide. Get a service manual if u can't figure it out. they are like 20-30 bux. I'm sure u will use it again. :thumbsup: Quote
