Trailtech Vapor Installation Problems
Fre530d
Hello Guys
So i am installing a Trailtech vapor speedometer.
It is possible to supply it with power so the backlight stays on so I used
the White/black cable from the tors (I cut the connector that goes at the black tors box that i don't use anymore) as positive lead and the black cable (ground) as a negative.
I saw this in clymers manual.
It's also possible to measure the rpm so I twisted the red cable around the sparkplug cable and
connected the black cable to the same ground as I did with the power supply cable.
But as soon as I start the engine the display starts reseting.
I just can't get it to work properly.
Anyone got some suggestions, experience?
Maybe a better source to tap power supply off?
WFG
Fred
Edited by Fre530d
drop the tors power... splice into your yellow with red line power that goes to your lights... thats constant running power.. should solve it...
how ever take that with a grain of salt cause im by no means an electrican! im just going by what common scence says how ever that not always the case with these :)
Ok thx , will try that and take that with a grain of salt ;)
