twojztt Posted December 27, 2006 Report Posted December 27, 2006 with porting,exhaust,filter,34mm carbs,v-force reeds,cool head,manifolds,what should i set the air adjustment skrew and the idle?thankyou. Quote
Bansh-eman Posted December 27, 2006 Report Posted December 27, 2006 wellassuming your pilot is correct 2 turns out... but the onlyway to know is how its runs at idle....also can you kickit over and start it coldwithout the choke? a cold motor should have to have the choke pulled to start it then once its warm you should be ableto start it without... Quote
twojztt Posted December 27, 2006 Author Report Posted December 27, 2006 wellassuming your pilot is correct 2 turns out... but the onlyway to know is how its runs at idle....also can you kickit over and start it coldwithout the choke? a cold motor should have to have the choke pulled to start it then once its warm you should be ableto start it without... what size pilot and main do you suggest for sea level 50 to 60 degree weather? Quote
Bansh-eman Posted December 27, 2006 Report Posted December 27, 2006 i want to say when i was running 34's i had a 155 main 52 pilot stock needle middle clip 2 turns.... start from there and you should beable to get it spot on Quote
twojztt Posted December 27, 2006 Author Report Posted December 27, 2006 i want to say when i was running 34's i had a 155 main 52 pilot stock needle middle clip 2 turns.... start from there and you should beable to get it spot on thank you very much for your time. Quote
