Ok, this is the first time this happened to me. I re-jetted my carbs for the winter a few weeks back, 270 main, 25 pilot, has airbox w/ lid, FMF SSTs, runnin at sea level, and 0-20
Check your compression....might be getting low on that...worn engines don't start quite as nice in the cold...
In that temp you should have to pull the choke. Might want to turn in your air screws...or bump that pilot up.
FMFs are notorious for liking a fatter pilot.
Thanks man, compression was 125 in each cylinder like a month or so ago, and I haven't really ridden since, so it should be ok. I ran the same pilots last year, I might not have the idle air srew on the same setting, so I might check that. Thanks man, :beer:
