cexualcensations Posted December 3, 2006 Report Posted December 3, 2006 Wondering if anyone is using the pvl ignition on there drag bikes. Is this a good setup to use or is the dyna ignition along with nology coil just as good. Quote
banshee332 Posted December 3, 2006 Report Posted December 3, 2006 Wondering if anyone is using the pvl ignition on there drag bikes. Is this a good setup to use or is the dyna ignition along with nology coil just as good. I like the pvl, thats what Im useing on the 10mill cub. Quote
bigscary Posted December 4, 2006 Report Posted December 4, 2006 I like the pvl, thats what Im useing on the 10mill cub. I had a PVL on my 14mm drag bike and it ran well but it was hard to start...... Quote
JaysonP Posted December 6, 2006 Report Posted December 6, 2006 I had a PVL on my 14mm drag bike and it ran well but it was hard to start...... timing adjustment? to advanced? does it run hot or cold? how high do these ignitions allow youto rev? 16-17k? Quote
bigscary Posted December 6, 2006 Report Posted December 6, 2006 timing adjustment? to advanced? does it run hot or cold? how high do these ignitions allow youto rev? 16-17k? it wasn't too advanced..... everyone I've talked to with one said they were just generally more dificult to start.... I put my stock ignition on and could stand next to my 593 and kick it over with my left foot in flip flops.....LoL Quote
banshee332 Posted December 6, 2006 Report Posted December 6, 2006 I never have a problem starting the 10mill cub with the pvl. 3-4 kicks is all it usually takes Quote
bigscary Posted December 7, 2006 Report Posted December 7, 2006 I never have a problem starting the 10mill cub with the pvl. 3-4 kicks is all it usually takes I don't know what the problem was.....it ran GREAT when it was running.....it was just a bitch to get running..... I am considering one on my 4mm cub..... don't know yet..... I guess it could be a bad ground? Quote
JaysonP Posted December 7, 2006 Report Posted December 7, 2006 I don't know what the problem was.....it ran GREAT when it was running.....it was just a bitch to get running..... I am considering one on my 4mm cub..... don't know yet..... I guess it could be a bad ground? maybe a bad ground, or bad plugs? Quote
banshee332 Posted December 7, 2006 Report Posted December 7, 2006 I don't know what the problem was.....it ran GREAT when it was running.....it was just a bitch to get running..... I am considering one on my 4mm cub..... don't know yet..... I guess it could be a bad ground? I think they are harder to start becuase of the weight of the fly wheel on the pvl. As you go up in stroke with the fly whell would turn less revolutions in 1 kick. So I would guess with the lighter rotor of the pvl it would get harder to start as you go up in stroke. Quote
bigscary Posted December 8, 2006 Report Posted December 8, 2006 maybe a bad ground, or bad plugs? no bad plugs....... maybe a ground..... I checked and rechecked all of the grounds..... Quote
blueshee03 Posted December 8, 2006 Report Posted December 8, 2006 no bad plugs....... maybe a ground..... I checked and rechecked all of the grounds..... could be because the pvl does'nt have the timing curve built in like a stock ignition. Quote
JaysonP Posted December 9, 2006 Report Posted December 9, 2006 could be because the pvl does'nt have the timing curve built in like a stock ignition. to bad youcouldnt have an external starter set up and use a DeWalt 500ft lb electric drill to start it. haha. all youd need is a shaft with a rubber coned end and something coming off the motor to start it. haha. 2,000rpms would start that motor i gaurentee. lol maybe buy a hotter plug? Autolites possibly? Quote
