This weekend at glamis my flywheel came loose a couple of times. There was metal shavings on the inside like if it wore the stator abit. The pick up coil and the bumps on the outside of the flywheel look to have rubbed together also. I want to upgrade my stator now and already have an adjustable stator plate. Where can i get a better stator and a pick up coil for cheap? I'm probly going to raise the wattage enough to change the headlights to a 50W set. What do you guys recommend for lights stator ect...?
