i ave an 04 banshee thats bored .40 over with coolhead 21cc domes paul turner pipes mild port and polish with k&n with pro flow adapter i had 300 mains needle in the middle with stock pilotand air screw out about a 1/4 to 1/2 a turn im in minnesota so elvation is just above sea level and temps wiill probably be 20 to 30 degees my gas is 92 octane with amsoil dominater 40 to 1. it blew up on me with this setup and i think im going to try 320 mains with a 30 pilot, dennis kirk only goes in increments of 5 or i would probably try 27.5 pilots . do you think this would be close and will the 30 pilots be ok please help im sick of rebuilding this thing.
did it blow up because it was lean? the stock mikuni needles go up in increments of ten... 310, 320, 330. I'd go to at least a 330s or 340s and see what happens; much better to be rich than lean, as you've so discovered. most bikes run 300s and 310s with pipes alone. in those temps, 30 pilots might be right on. i'd dial in the pilots by how it starts. if its starting fine, leave it alone. the "blowup" would be more caused by needle and main settings. get some more fuel in that that so you'll quit blowing it up.
ill try them i tried 340 mains this summer around 70 to 80 degrres and i had to remove my airlid to get it to open up but know that its getting colder they might work. im not sure why it blew up this time but i know the other 2 were because of jetting but thanks to these forums i thought i had it pretty close. but the every time the cylinder look the same it looks almost like the ring cathes the exhaust port or they just seem to get messed up in that area. i just want to get it right this time
thanks for the input.
Take a pic of your pistons w/rings still on and post them. Can help you determine the cause so this doesn't keep happening. At this rate you are going to need to resleeve or buy new cyls very soon. Have you split the bottom end before? Also w/as many problems as you've had I would do a leakdown test when you get it back together before you ever start it.
you cant fix a mechanical problem by adding fuel. if youre rings are getting snagged in the exhaust port thats NOT a function of the jetting. thats more like a porting or cylinder boring issue. were all of the ports correctly chamfered the last time it was ported or bored out?
who did the port job and cylinder boring?
how do i give permission to look at the pics. its looked to me like it catches but im not sure so hopefully we can get those pics to you. i did get it ported and polished alomg with the .40 over bore, it was done by bill bune in anoka minnesota he is very reputable and has been in business for over 30 years. i eas going to bring my jugs to him today to get them honed maybe he can take a look and find something. its like this has been happening since i first bought it.thanks a lot
Can't see the pics...
This is the error message
Please enter your T-Mobile phone number and My T-Mobile account password to enter your album. If you are a guest trying to view a friend's album or journal, please let them know to set their privacy to friends only or public and invite you back to their album.
i think this will be easier enter the phone number 7637425410 and the password is b3qscp. i tried to make the pics public but they wont let me and ii tried to copy but it wont let me paste on this page. im not real good at this stuff . thanks. that website is www.t-mobilepictures.com
Edited by burn1banshee
come on guys i know its a pain in the ass to see the pics but i really need some opinions, otherwise maybe someone can tell me a good way to put pics on these treads.
Save your pics to a service like www.photobucket.com
Can you take some better shots of these?
Doesn't really look lean to me. As was stated before was the ports properly prepped before the engine was reassembled? How much piston to bore clearance?
I think the squish is too tight on the one piston that got chewed up. Notice it melted around the edges, NOT in the middle....
Possible a bad crank bearing on that side allowing the piston to touch...or almost touch the head itself.
I'd be tearing that whole motor down, have the crank checked, the cylinders bored and chamferred, and the head checked for flatness.
Then check the squish....
is there any way to check the crank without having to tear the bottom apart. i really dont want to have to but if thats the case ill try. thanks a lot for posting the pics next time i will try that. i spin the crank and it feels real smooth but i dont know if theres more to it than that or not thanks again
