Im running DG pipes on my shee but it leaks alot at the exhaust port tried putting some red silicone on but comes loose after a while. What do you guys suggest I do? :confused:
Yea maybe you forgot to put the Orings.That happend to me because I never knew I had to take them of the stock pipes.It would spit out oil at my rear fender and burn my ankle.
Same thing is happening to me too.. I'll have to check that o-ring..
get my shoes all oily.. :verymad:
I run my T6 for many months without that o-ring, because i didnt know about it, and my pipes are not leaking. So is it a big deal to keep riding without it ?? or nothing wrong could happen??
If your pipes don't leak then I wouldn't worry about but if they do you should fix it because it's robing horsepower. The O-rings that come with the top end kit are one of the best O-rings I've found and red silcone is the way to go. I know it only lasts a few trips but it's the best thing I know of.
