Badley Posted November 13, 2006 Report Posted November 13, 2006 OK did a search found nothing.I got a new set of stock carbs put them on and rode yesterday.It was good but not great poor throttle responce.Took the plastics and air box off to see if the carbs were syncronized and they were off.I just set them and noticed that the right one (when seated)opens quite a bit more than the left one.Also noticed I have a twist throttle when I try to adjust throttle up at the throttle only the right one moves.Throttle and cable is a new motion pro vortex.Is this normal,I would think they should move at the same time and when adjusted should also move at same time.Am I missing something.I need to here from someone who knows,Thanks. Quote
wesw Posted November 13, 2006 Report Posted November 13, 2006 you need them to raise up at the same rate. you will have to adjust to get pretty close jeff sells a carb sync tool that works well also Quote
dajogejr Posted November 13, 2006 Report Posted November 13, 2006 The adjuster at the twist throttle is for taking out the majority of the slack. once that is done, all fine tuning is done with the adjusters on top of the carbs. You should have a little slack before they open, or else R's are gonna rise when you make a turn... Do you have the idle screw kits installed? Yeah, Jeff sells the syncrometer, as wes said....it is the bomb and foolproof to use! Quote
Badley Posted November 13, 2006 Author Report Posted November 13, 2006 The adjuster at the twist throttle is for taking out the majority of the slack. once that is done, all fine tuning is done with the adjusters on top of the carbs. You should have a little slack before they open, or else R's are gonna rise when you make a turn... Do you have the idle screw kits installed? Yeah, Jeff sells the syncrometer, as wes said....it is the bomb and foolproof to use! Thanks guys,I completly forgot the adjustment on top of the carbs.Yes I have the idle screws and torrs is gone. Quote
Bandit Posted November 13, 2006 Report Posted November 13, 2006 I still have TORS and who is that that sell the sync tool? Quote
dajogejr Posted November 13, 2006 Report Posted November 13, 2006 I still have TORS and who is that that sell the sync tool? Jeff does at FAST Racing.... www.farmandsandtoys.com Quote
