Badley
About Badley
  • Birthday 11/11/1958
Contact Methods
  • Website URL
    http://
    New Jersey
    1998.FMF Fatty pipes,450 shocks.work in progress.
Badley's Achievements
  1. For those who use or used A 2 INTO 1 38mm. Does it use less gas than the stock setup.In a couple of hours of riding I go thru 5 gallons of gas which is no big deal. I might try a friends 2 into 1 and just curious if it uses less gas. I gathes 2 26's actually I have 28's so 2 28's =56 as opposed to 1 38 So I would say yes anyone have an answer.Thanks
  2. I just got a jenssen stablizer new with no dircetions. I know where it goes on the steering stem the round clamp but where does the other side go.Can anyone post a picture tonight.I am riding sunday and would really like to get this on.Thanks.
  3. Forget wall insulation,I just did it and it sucked.I used it for 1 ride took it apart and just did not hold up well.I got the real stuff from Rocky Mountian ATV for 5.99 per silencer.
  4. The company is not look it is called Berik. They are good boots my friend has them and likes them alot.for 90 bucks I would try. which modle pro or contender.
  5. Thanks dan and the wheeles are working out great.
  6. I got a set of exhaust clamps off ebay and after 3 rides they are toast.Melted and rotted away.Who makes some clamps that will not melt and keep a good seal.I am ordering some parts from Rocky Mountian and they sell cascade billet clamps for 40 bucks.How is cscade.Thanks.
  7. Thanks guys,I completly forgot the adjustment on top of the carbs.Yes I have the idle screws and torrs is gone.
  8. OK did a search found nothing.I got a new set of stock carbs put them on and rode yesterday.It was good but not great poor throttle responce.Took the plastics and air box off to see if the carbs were syncronized and they were off.I just set them and noticed that the right one (when seated)opens quite a bit more than the left one.Also noticed I have a twist throttle when I try to adjust throttle up at the throttle only the right one moves.Throttle and cable is a new motion pro vortex.Is this normal,I would think they should move at the same time and when adjusted should also move at same time.Am I missing something.I need to here from someone who knows,Thanks.
  9. I just got 450 a-arms also for 100.00.You have to cut one of the mounts down and then put a spacer to make up the missing space.I got all the info from the guy that already did it.Just do a search.
  10. Thanks for the fast shipping and awsome carbs.These look new.5150Banshee is OK in my book.
  11. Thanks guys. I got it straight.Took it to to my old straightening tree and with a large cresent wrench and a peice of pipe got it pretty straight. A little creative coaxing.
  12. I have been rebuilding my first banshee and got to the steering stem and where the tie rods mount one side is bent down.Is it supposed to be that way or is it supposed to be straight.Thanks.
  13. Here's one for Bansheedan. Thanks for the wheeles and grab-bar and light speed shipping.
  14. Dan just got the wheeles and grab bad and am very happy.Also light speed shipping.Thanks.
  15. Does anything need to be reemed.These are the oner off ebay I just saw.I am aslo interested.
